I was wondering if anyone's ever heard of an issue such as the one I am experiencing at work. Can't be specific about make/model of computer, let's just say it's from a large OEM and is a BTX mid-tower Pentium D 930 system running on a Radeon Xpress200 motherboard. A whole shipment of these systems (200) have major floppy drive issues right out of the box. Data Error reading drive A: everytime I boot with any one of my netbootdisk.com boot floppies. Floppy drive in all of these systems is a Mitsumi drive MANUFACTURED IN CHINA (remember the all caps part, it will be important later on in the story)...... Now, I was curious, so I removed the drive from the tower, and hooked it back up..... In every single case, it booted just fine........ Soooo.... i'm thinking it's the data cable being routed too close to the processor or something, so I manage to use the cable harness to suspend the drive near the floppy bay in the same sort of orientation as it would normally be in.... again, boots fine..... pop the drive back in the bay, data errors all over the place..... so, I start thinking it's a grounding issue.... so, I ground the drive to the drivebay with a length of wire..... still boots fine...... so, i'm running out of ideas...... i go grab an identical Mitsumi floppy MANUFACTURED IN THE PHILLIPINES and slap it in there...... in all cases, works fine..... So, I go slap the CHINESE one into a similar Pentium 4 3.2GHz system with and identical case but running an Intel 915 motherboard..... well s^&t on a shingle, it works great....... okay.... WTF is going on? drive works in different system that uses the same case...... so it would appear that the CHINESE drive is somehow incompatible with that particular hardware combo, but only when installed in the case..... I have no idea what the hell the problem is, only that the solution is to replace all 200 drives with a Panasonic model (tested on 10 so far, 100% success!)....... And the only other reference to ANYTHING like this on the net refers to an IBM PC300GL but he never figured it out either and attributed it to a ghost inside his computer........ So, any ideas at all? Only thing I didn't try was all of the hardware inside of a different case, since I don't happen to have any BTX cases laying around that are any different....... and I don't think 200 cases could have a fatal flaw in them......
Edit: BTW, these cases all have 2 external 3.5 bays, and the drive behaves the same way in either bay (works on the 915G/Pentium 4 combo, not on the Radeon Xpress200/Pentium D combo)
