IDversusEGO
- Oct 30, 2003
I need to find some of the right angle SATA connectors to crimp onto my leads so I can clean up my cabling. anybody have a good source for this kind of thing?
true...but it doesn't tell me of the personal experience that many people may or may not have had with a vendor.
http://www.google.com/search?hl=en&...ft:en-us&q=sata+tb+hard+drive&aq=f&oq=&aqi=g1
I see a few places on there that I wouldn't buy a hard drive from.
Strange you didn't ask any of those questions in your OP...Not even close.![]()
Here you go.
http://www.performance-pcs.com/cata...ge=product_info&cPath=60_164&products_id=1220
Be sure to pick the correct cap (pass through cap or end cap).
Its a bit pain in the ass to install. Be sure not to use the cap to push down the wires at first. You can easily slip and destroy the cap.
~Edit~
Seems though the black is on backorder as soon as your place it in cart. Red and green are still available.
http://www.performance-pcs.com/cata...ge=product_info&cPath=60_164&products_id=2335
http://www.performance-pcs.com/cata...ge=product_info&cPath=60_164&products_id=2336
http://www.frozencpu.com/products/1..._EZ_Crimp_Connector_Black.html?tl=g44c155s649
I used 2 of these added to a line on my Liberty 600 so I would only need the single wire. Worked clean and easy.
How much of a pain are these to replace, exactly?
