A buddy of mine has a Seagate STAC3000101 3TB external hard drive. It uses some base to power and basically has the SATA power/data showing to plug into. He said that it basically stopped showing up in Windows so I took it to see if I can help.
Instead of using the base I plugged a SATA power and data cable into the drive directly into the motherboard. Doesnt show up in Windows nor in the BIOS. It hung for about 30 seconds at the BIOS when detecting hard disks.
So I then used the base with usb and power cable. I could hear that it was trying to spin up but it would try, click, try again, click, try again, click try again, click.
Any secret tricks known to get it to spin properly and read? What are the options for getting data off using local tools/software?
