Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Got a buddy that purchased a Maxtor 200Gb USB harddrive. He plugged it in and it's not showing up. He's running Windows XP and the harddrive box claims it's a plug & play. Any tips?
Did he make a partition on it?
- use computer management, disk Management to partition and format the disk (which also assigns a drive letter to use it)
I have the same problem with the Nexstar3 for 2.5" HDs. It will only work on the direct USB port of my notebook, but on my desktop, nada. Same story with the USB hub. What gives?
