External Hard Drive Enclosures and Media Server Setup
Status
Not open for further replies.
decade146
I want to set up 2x2TB SATA hard drives (Western Digital WD20EADS) in Raid 0 connected to my laptop (USB or eSATA) and then to my PS3 (ethernet or USB). I think this is this is the most convenient setup to stream blu ray rips from my laptop to my PS3 and also be able to edit files while avoiding swapping connections.
From my understanding my hard drive is limiting the transfer rate in this setup. Would an eSATA external hard drive interface would be unnecessary? Should i just stick with USB connections?
I am having trouble finding the right external enclosure. Some of them on newegg state they support only to X TB so I only found two that I am certain will work with my hard drives with 4TB of space. Can someone clarify if this is only because of when they were marketed or is there something else involved?
Please give me some recommendations on which external hard drive enclosure to choose. Thank you so much :) !
My budget is $100. Here is what I'm looking at...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817198032
http://www.newegg.com/Product/Produ..._re=rosewill_enclosure-_-17-182-144-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392017&Tpk=NST-400MX-S2
I'm a bit confused here: Why RAID 0? What files will you be editing?
Status
