So I'm looking for an external drive to backup my 500GB drive, which has about 60GB free, then some backups on my current drive. So I'm thinking 750GB should be enough, and I heard some things about 1TB sized drives failing apparently.
Edit. now that I did some research, I might be fine with a 1TB drive, if the reviews are all good, why not.
So here are the two 750s I'm looking at.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136176
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204087
And then, if I were to get a TB drive, maybe this would be the one.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3572142&Sku=M261-8184
Thanks.
Thanks.
