Extended partitions.
DeathPrincess
Someone I know just got a nice new shiny laptop thats bigger than 15". (it wasn't me)
They asked me for help because they can't get a game to install on the C drive because it's too small. Because of EAs marvelous way they do things, it will only run off C if you want to use DLC apparently. But being a laptop with a laptop HDD it's rather small. C (primary) is around 60gb while theres another 160gb on D (logical).
SO as i've done a million times before loaded up the disk part of computer management, gone to disk. Shrunk the D by 15gb. But it's in an "extended partition" (the green line) and even though i've done this with loads of disks before, i've never been against this foe. Google just told me to use lots of freeware (x86 only) and paid for software (for 64bit). Lucikly, as chance would have it, the OS is 64bit.
All I want to do is add 15gb of space to C from D, but it seems impossible without paying people, which I'm kind of against as this ability should be in the OS somewhere.
i could delete the whole partition D after transferring off all the data, and then replacing it on the new D. Would deleting the whole partition remove the green line of annoyance?
Or is there a simple way of doing this that I am not privy to?
I feel like such a noob today.
OS is Windows 7 home premium. Drive is a 5200rpm laptop drive of non giant proportions.
Thankyou
yes, this would be do-able without additional software.
You would need to delete the existing D: partition, then use the diskpart command within a command prompt.
here's some info on using it
http://support.microsoft.com/kb/325590/en-us
edit: sorry, I take that back. Diskpart will not work on the boot/system partition.
how about something like a GParted livecd?
Gah. It seems such a simple thing to do, but it's just strangely forbidden...
So deleting the D partition and expanding the C to fill the new space wont work?
There must be some reason why this isn't allowed...
Thanks for the suggestions!
this should do.
I would recommend making an image of the C: drive before-hand though.
http://gparted.sourceforge.net/livecd.php
and you would still need to delete the D: partition
The "x86 based" part worries me. Will it work on 64bit OS. I know the disks themselves are the same, but it is a worry.
The imaging is always a good idea with any disk type activities, as i've found out many times before (damned SSD double failing)
How about this?
http://www.partition-tool.com/
I've used their free disk clone utility with good results.
That looks good, but the free (home) version is 32bit only!
Surely there must be somewhere within the OS that undoes something that the OS did?
the GParted will work. x86 just means it will only work on x86 CPU's; ie, not Itanium, PowerPC, etc.
It is not dependant on the host-OS since it boots into its' own OS.
x64 is just an extension to the x86 processors' instruction set; they are not truely 100% 64-bit CPUs
edit: FYI, here's a link on the gparted site that may be of assistance too. Granted it's for Vista, but since 7 is based off Vista it will be essentially the same steps.
http://www.howtogeek.com/howto/windows-vista/using-gparted-to-resize-your-windows-vista-partition/
Darn, sorry about that. I missed the 64 bit requirement in your OP.
What about this? It appears to handle both 32 & 64 bit.
http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html?tag=mncol
Thanks for the suggestions! I got it to work using the first one while the second was downloading, but they would have both worked! (still annoyed that microsoft desn't even offer a tool to do this). But then the game wouldn't run on the laptop anyway...which is typical! I ended up donating the old machine I dont use anymore to play the game on which has 2 TB drives so wont cause any problems, and I can still use it as a rendering node, so i'm happy!
@j-sta I know about the x86 part, but it still worries me. SO many games and such for x86 programs dont work with 64bit things for so many strange reasons it just gets me all "here we go again" when I see the "x86 only" tag on anything! But you are right there is no need to worry!
If there is no D/extended partition behind C then disk management will gladly extend C for you
The question is extend partition. I have to say that extend partition through the Partition Assistant Home Edition also can work well. It is free for use, and you can experience its advantages in advance. After you finish the operations such as format partition, extend partition and so on, you will find it worked wonderful, I primise, you will never want to change another tool to finish the work. Like me, I do not want to try another tool to work the operations I just mentioned after my friends introduced to me.
Believe it ot not, depend on you, I just tell you my true feelings about it.
