export email settings in outlook
lone wolf
hello all,
I know that in OE you can export your email settings, I can't seem to to that in outlook though, is there a trick to do this or just not possible?
thanks
Assuming new Outlook 2003...
If you're brave, wanna try exporting/importing this registry key.
<inserts warning of backing up new PCs registry first>
HKEY_USERS\S-1-5-21-<some long number here..varies from PC to PC>\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Outlook
Doesn't save the POP3 password though.
Theres some utility someone wrote which I think the free version/demo saves the settings..just not the password. Google "backrex"
So, outta luck if you don't know the password.
Thanks for the reply, I have been trying this for awhile now. I have moved all of my users pst to the server, but could not move the settings for backup. I will be glad when i get my exchange server up and running.
