Dr. Righteous
- Aug 1, 2007
The idea of water cooling is pretty cool but the parts are Ridiculously expensive for such simple pieces.
12v water pumps $80? Screw that.
Anyone consider this?
http://cgi.ebay.com/ebaymotors/Mr-G...8371d2e63&_trksid=p4506.c0.m245#ht_500wt_1137
And water blocks?
Buy some plate copper or aluminum, form them into a cube, solder the seams and then soldier in the inlet and outlet tubes. Maybe add some metal screen to the internals to create water turbulences.
For the radiator, how about a transmission fluid cooler for $18 bux at the auto parts store.
And water blocks?
