Evga mothernoard
mudchucker
Just having a problem trying to set up two mother boards in my computer when i plug the gforce 8600 card in it will detect one card then i plug the other one in it detects only one card it wont show me sli or any option that both are running.I have all the lattest drivers and everything. I says sli is disabled when i run GPU-Z SO I dont know what to do mabe buy anouther motherboard that works.
er, what EVGA motherboard ? They make more than one. Got the SLI bridge thingy connected between the cards ?
First, which EVGA board do you have??? The board must be SLi capable.
Secondly, both GPUs have to be the same.....ie two GeForce 8600s or whatever you are using.
As Bill said, you have to connect the SLi bridge between the two cards....and power cords from the PSU.
Also they use PCI-e slots, but that should be marked on the mainboard as to which are used for SLi.
Lastly, SLi is activated by the driver software. When you boot up, at the desktop, in the toolbar should pop up a message that SLi has been detected; You then click on the pop-up and are taken to a screen where you click a box to enable SLi.
You probably will need a restart after securing the second card for the SLi message to come up.
The screen will blink and go black, then direct you to restart. Once you restart the computer, a pop up will appear telling you SLi is enabled.
