not enough ram to even give -bigadv a shot.
I keep having:
Attempt to access beyond end of device
hda: rw=1, want=2097008, limit=2088387
or line after line after line of that with the want number going slowly upappear on my notfred for my Q9650....it's flipping annoying.
I was hoping the LinSMP distro might not do that and might have some advantages as notfred hasn't been updated in ages.
I'm allocating 1024MB to the VM BTW
I agree with Zero, that it's likely another issue. I never seen those messages before. I have allocated as little as 2.5GB of RAM to my VMs for testing -bigadv. I even reduced the threads to 7 in order to determine minimum required resource allocation to run these units. What happened in my case is the client stalled without any CPU activity. I have left it for over 30 minutes and no CPU activity ever commenced within the experimentation period. I just gave up on it.not enough ram to even give -bigadv a shot.
I keep having:
No performance difference for me between running on a full Fedora 10 distro and running notfred's. As for making the VM, you can do that with the Workstation trial, or you can use Server which is free (although it only supports 2-core VMs, but you just edit the .vmx file once you've made it to solve that problem).there is that, as an option, I was thinking doing a full install there would be some loss of folding power running all the stuff that I did not turn off.
That's an interesting performance result. Many people here have posted that converting dual-core VMs to one single VM results in superior performance. I have always doubted it and in my case it's still up in the air whether it's better in regards to PPD. I will have to look at old logs in my shut down VMs and compare with the sole running VMs to extrapolate the results.Currently, I have a cut down "full" install of openSUSE 11.2 running in a VM on my main system (Q6600@3.6) alongside the GPU client within Win7. It's currently doing around 5600PPD when I'm not actively using the machine. The PPD numbers on this VM is a bit lower than I was expecting. Previously I was able to pull 200-400 PPD more with this machine (when not in use) while running 2 VMs with 2 cores. Those two older VMs were running cut down "full" installs of openSUSE 10.3. All of these VMs were running KDE.
I saw a definite increase after the 2.10 core was released, in any case. I went from 2000-2200PPD per VM to 4800-5800PPD for the single VM (depending on if/how the system is being used for other things).That's an interesting performance result. Many people here have posted that converting dual-core VMs to one single VM results in superior performance. I have always doubted it and in my case it's still up in the air whether it's better in regards to PPD.
I think on my systems it's a mixed bag but cannot confirm it at this point because I have to restart the old VMs and look into the logs. For example, one system is averaging 6.5 minutes per frame now, and before with 4 VMs, each one was averaging about 20-22 minutes. However, on another system with identical motherboard but different processors: 4 VMs were averaging about 17-18 minutes per frame, now does around 3.5-4 minutes per frame. This is from memory without checking the actual logs.I saw a definite increase after the 2.10 core was released, in any case. I went from 2000-2200PPD per VM to 4800-5800PPD for the single VM (depending on if/how the system is being used for other things).
One thing for sure, the systems are definitely a lot snappier and far easier to get running from a reboot than having as many as 4 VMs running concurrently. Perhaps more importantly, Stanford prefers the much quicker turn around times and I will leave things they way they are for these reasons.
All of my 4 difference PCs give me that same message in Notfreds, so I don't think it's a memory issue or anything either. I have no idea what causes it, but it doesn't affect its performance, so I don't mind it, heh.
No. I had tried it but didn't see any difference.One question: are you using the "export MPICH_NO_LOCAL=1" command?
Can you use the MPICH_NO_LOCAL command with the eVGA LinSMP?No. I had tried it but didn't see any difference.
I have no idea; I've never used the EVGA distro.Can you use the MPICH_NO_LOCAL command with the eVGA LinSMP?
