evga combo motherboard
krouch
I was wondering is the evga motherboard that comes with the 7800 gt comes is up to par with the other top mobos. I was looking to get the dfi sli mobo and just buy the 7800 gt separately but since i have seen the combo to be quiet cheaper then i was just wondering if the evga mobo is worth buying?
Supposedly it's a rebranded Jetway mobo that overclocks very well. Check out the evga mobo thread in the forums.
It has good overclocking features but it is loaded with memory compatibility issues :(
You could just sell it and get the DFI if that's what you really want. Or just get the cheaper 7800GT since the one with the motherboard combo is $379 and you can get an eVGA 7800GT for $285 or so after rebate.
I'm facing the same problem
any suggestions on any others good mobos in 120$ range...
I'm building my first pc... sooo I heard DFI is not for noobs... so I don't know
but curently I'm looking at Abit K8N Sli mobo... it doesn't use any fans sooo I like the fact that its not going 2 be noisy
I jsut purchased one for my friend and its $359 at tigerdirect ( i know there not the best but it was the only place i could find the combo :( )
Anime_Fan said:
I'd like to sell mine and go with the DFI :)
Anime is right. The EVGA is not a bad board and it can o/c well BUT..... you must get the right RAM for it or else you're limited to 245-250 HTT. The DFI has no such limitation. Do check out the large EVGA mobo thread here or go to the mobo forum at evga.com. Hope this helps. :)
