I got the EVGA 680i SLI board a couple months ago, I have a E6600 and some OCZ platinum DDR2-800 RAM. I am right now overclocking the system to 3Ghz using the PDF guide from nvidia, at these settings:
FSB: 1360 QDR
Memory bus freq (unlinked): 1020Mhz
CPU voltage: 1.350v
Mem voltage: 1.850v
FSB voltage: 1.300v
nForce SPP: 1.350v
Now at these settings, things are mostly stable, but my memory runs incredibly hot, and I noticed when I moved my computer into a new case that the heatsinks have begun to separate from the RAM chips.
I bought 2GB of Corsair Dominator DDR2-1066 memory to replace the OCZ stuff. I am wondering what the best settings would be to get a 3.0 - 3.2 Ghz clock. Do I need to up the voltages as much as I did? Should I do anything with SLI memory profiles?
I haven't really overclocked before so I'm not sure if my original setup up top was somehow incorrect. If anyone has any comments I'd appreciate it. Thanks
FSB: 1360 QDR
CPU voltage: 1.350v
Mem voltage: 1.850v
FSB voltage: 1.300v
nForce SPP: 1.350v
