eVGA 680i MB and cpu core
masaville
Anyone have an eVGA 680i MB with an E6700 cpu? If so, can you tell me what your cpu core is showing and if the voltage is stable or if it fluxcuates. My drops to 1.14 and 6X cpu clock when idle and I'm just wondering if that's normal. Couldn't find anything in the BIOS or manual on it. Is that just a power-saving mode feature? Thanks!
Figured it out. BIOS option.
I have that setup running as I type this reply and the voltage I have right now is 1.4v only cause I am running the cpu @ 3.2Ghz, the voltage is stable and I have not seen it fluctuate at all and it has not crashed yet and I ahve been playing FEAR, FEARXP, HL2, and Oblivion for the past 3 days for about 5 hours each day. :p :D
Yeah, it will drop to x6 and lower the voltage when in idle to save power. My DS3 did the same thing.
There are a few settings in the Chipset advanced settings that I have disabled to keep it from doing this:
CPUID Maxval = disabled
CPU Thermal Control = Disabled
C1E Enhanced Halt State = Disabled
Try this and see if it helps mine has yet to fluctuate at all.
:D
