Ok, so i've been fighting with my computer for a while now and i've finally decided to swallow my pride and ask for help, plus i just got internet at my news place.
I just moved into a new place and realized quickly that the temps on my OC on my cpu was a little hot, just a couple degrees, not really anything to worry about but i treat my hardware very good so i decided to turn the oc back down to stock until i got my water cooling loop up and running. My gpu was also starting to artifact in games, so i dropped the oc down and it kept artifacting so i turned in back down to stock and it was fine.
after i did this i felt my system was being a little buggy, it would start up and my mouse and keyboard would not respond, it would randomly freeze and then my system started booting with no video response. The fan on my gpu was spinning and everything booted fine all the way into windows. (the only way i know it booted into windows is because i left my speakers on to see if it would boot all the way and it did.) And then when i would restart it via windows or the reset button it would hang on error code 25 via the LED indicator on the motherboard. I have an old 8800 gts for times like this and i popped out my 55nm gtx 260 and threw in the old 8800 gts and it booted like a champ although it still hung at any restart on error code 25. i would have to power off the system and sometimes ever unplug it until the all the power drained out and then it would boot fine.
I just blamed it on vista (32-bit) and decided it was way past due going back to xp. After i backed everything up i wiped the hard drive and got a fresh install and everything was working fine, i didn't restart it do to thinking that the fresh install solved the problem. I installed the drivers for my gtx 260 and thought it would work fine, popped it in and got the same problem no video, and i was still getting the error code 25 on restart even with the 8800 gts. I started to think my card was bad but then i put the 260 in to a different pci-e slot and i got response!! but all i could do was boot into the bios and it was telling me to put the card back in the 1st slot, which was still not working. I googled everything i could on the error code 25, i reset the cmos which helped but didn't really fix anything, i updated the bios on my motherboard, updated the 260 drivers to the newest 185 drivers, i updated the drivers for my motherboard and nothing. Everything i have tried has now worked, i checked to make sure everything was plugged in right and it is. I thank any one for reading this far and hope someone could help me with my problem.
if not i guess i'll be in the market for a new motherboard.
The system i'm running is
c2d e6600 was oc'ed now everything is stock
2x2 gigs of crucial ballistix
evga 55nm gtx 260 and evga 8800 gts
creative audio sound blaster audigy 2 zs
antec TPQ 850
Thanks for any help!
antec TPQ 850
