evga 260gtx
xainish
does this come with sli connector? all the pics i see of it does not include one in the cables. does it matter what cable i use if i buy one separately?
SLI bridges always come with the motherboard. If you have an SLI compatible motherboard and do not have a bridge than you will need to ask your motherboard manufacturer for a bridge. The spacing of the board may differ between boards so you can't always just pick up any bridge unless it is longer than the space and flexible. Your manufacturer may replace it for free and even if they charge you, at least you know it will fit.
