BUT THERE IS NO LINK!!!
Most excellent news...they can take all the time they want to get the RAID drivers out as long as they come out before my 2 new Dell 7200 160gb sata drives get here next Wednesday![]()
Well, all those things are valid, but at the moment I am sort of stuck in the middle of nowhere, and don't really have access to compressed air to blow the vent out. I even lifted the back of the computer to let some air under the chasis, but it does not seem to affect the heat. Maybe a laptop cooler would help, but I am not sure what they have in the SuperWalmart here. BTW I did not OC my GPU, with the modded drivers from laptopvideo2go.com I can't seem to be able to OC, it gives me "test failed" message.TANWare said:There in lies the problem, control of the fan speed. There is one heat pipe cooling the cpu and gpu. as the gpu heats it reduces the efficacy to cool the cpu but the fan does not seem to respond from the gpu's temp.
I haven't found a way to conrol the fan yet but some suggestions are:
1.) if overclocking the GPU bring it back to stock.
2.) turn on wait for vsynch.
3.) turn down some graphic features.
4.) Find a room with AC
5.) use some compressed air to blow clean your heat pipe, dust can cause a real issue there.
also Everex list's the spec on the vga as 105C max:
*TEST Specification Median Average
CPU 95.0 85.0 85.0
North Bridge 90.0 88.1 88.9
South Bridge 90.0 78.1 78.9
DRAM 85.0 75.0 75.8
VGA 105.0 91.2 92.0
V-RAM 125.0 86.3 87.1
HDD 60.0 44.6 45.4
Touch Pad 55.0 45.6 46.4
Keyboard 55.0 48.7 49.5
Inverter 55.0 55.0 55.8
Palm Rest 55.0 50.4 51.2
im sure superwalmart had compressed air cans.Well, all those things are valid, but at the moment I am sort of stuck in the middle of nowhere, and don't really have access to compressed air to blow the vent out. I even lifted the back of the computer to let some air under the chasis, but it does not seem to affect the heat. Maybe a laptop cooler would help, but I am not sure what they have in the SuperWalmart here. BTW I did not OC my GPU, with the modded drivers from laptopvideo2go.com I can't seem to be able to OC, it gives me "test failed" message.
I wish nTune had more control over the fan settings, right now it is all greyed out !
Thanks anyway,
DK
Anyone know of a way to undevolt in linux ? (fedora 7)
Oh, of course, RAID support *right* after I give the damn thing away to my ex. Sheesh!
if you make your customized cover plate, DONT make air inlet right above the fan. the idea is that the airflow has to be directed: cold air has to be drawn from somewhere else far away from the fan and cool other components before making its way to the fan. if you have a hole right above the fan, the fan will just draw cold air in from outside to cool the CPU heatpipe and wont draw hot air from the rest of the chassis out (in such case, as a result, the CPU heatsink would get cooler while the GPU, RAM, wireless card woud get hotter). if you still insist on make air inlet above the fan, at least keep that inlet smallPulled the screen off of mine sometime back not sure it really made a difference. Is plastic on mine. One thought I have had but have not gotten the chance to try it yet is an opening around the exhaust fan to draw in cooler air through the fan. Most laptops I have encountered are usually designed this way. The key would be to allow cooler air to enter the fan but at the same time be able to draw a decent amount of air through the original opening. I would like to try and make a mockup cover that has the original opening then an additional one over the fan, if that worked satisfactory then would modify the factory cover, just havent had the time to try it yet.
Andy
yes, you are correct. there is little correlation between the CPU and GPU's temperatures (sometimes i saw 50C for CPU and 102C for GPU) because the stock 'thermal pad' did not link the heatsinks of the two together well enoughwell that might explain why on ONLY graphic intensive games, such as various MMO's .....my laptop quite literally....just...powers...off after playing for a random amount of time. the keyboard is SUPER hot a lot of the times, meaning the gfx core probably hit over 100C easily..... @.@ WHYYYYYYY EVEREX...WHyyyyyyyyyyyyy
If you guys are running the laptop as a stationary desktop replacement, why not just take the cover off? It solved all my thermal issues. Putting a laptop cooler pad underneath it with the cover off makes a huge difference in operating temps.
Are you afraid of pulling off 4 screws? You get what you pay for, sometimes cheaper things just take a little more effort to get working.
It's kinda like suggesting that if your car overheats a bit you should take the hood off to increase airflow. Can it be done, sure. But is that something most people would find desireable/acceptable, no. They're gonna pay the money to take the car to the mechanic to figure out why it's overheating (say perhaps a bad/underrated thermostat).
I would rather not have to disassemble my laptop whenever I want to use it, then reassemble to take it on the go. Sorry, but it's just not a practical solution for me.
