Things always feel better quality when they are metal, especially when it is milled from aluminum.Originally posted by Dome
why aluminum for a fan?
Originally posted by kleptophobiac
You made me blink there for a second...
recommending it
Originally posted by -=iNsAnE=-
sorry for jackin your thread.. but its all on the same topic![]()
there is no magic material (al in this case) which manages to be cheap and still produce silent air.
before i'd buy it you'd have to explain to me how changing the casing of the fan (not the blades at all) to aluminum helps reduce noise or move more air.
Originally posted by zer0signal667
An aluminum fan blade would be pretty impractical in a fan this small. It would weigh more than a plastic one, so any imbalance would wear out the bearings more quickly and it would put more strain on the motor when it turned on. And the reason for the Al housing is just for looks, there's no reason it would perform better than a plastic one.
thats not what he's saying.. forget thats its even supposed to be aluminum.. because the blades arent.. he's simply asking if the fan performas near its specs regardless of what its made of.. i'd like to know too since i have the same fan as well and am thinkign about upgrading
bump from the 3rd page, btw...
Originally posted by sKiTz0
one thing i thought id add... the side that the fan blows air to is UGLY. have it blowing inwards.. the other side has a white plastic structure to hold the wiring with the evercool sticker on it that ruins the whole thing
