Evercase ECE0588 Low profile w/VESA
You know... with a 40mm thick power supply that case could probably take a 2-slot low profile video card (e.g., this GTS 450).
Anyway, maybe you could ask this guy about the case. All those cases - the Evercase ECE0588, ECE0548, ECE0528i and the equivalent Jou Jye models appear to be identical inside, with the only difference being the bezel.
Glad to see someone is using it, though I dont really want to register to see a couple build log pics.
Neither of those have expansion slots...
you're not missing anything. No real close up shots, and 3 of the pics are focused on the 2400 Pro and the mashed up HS attached to it.
Does anyone have any thoughts/experience with this case? I spent some time looking for a low profile mitx case with VESA mounting and this is what I came up with.
Seems like a good case for us.
http://www.evercase.com/2product/e0588.html
Hello, I recently bought a case equivalent to that, also there is a version of JouJye with Vesa. I can now tell you that is very intelligently designed and the quality is not bad.
Here are some pictures and my first impressions. Greetings
I was pleased to see your thread. It is great to get some good build pictures, even if I did need to use google translate.
I was aware of the JouJye version but made this thread regarding the Evercase as they are commonly listed on ebay.
I just need to find a cheap used mobo so I can get this thing setup!
