ESXi Home server Checkup
Hi there everyone!
Discovered ESXi last week, so basically been thinking about it every evening.. :confused:
I put together a list of parts that I would like to order, but I do want a final checkup from you guys before spending any money on it. ;)
Parts list: https://docs.google.com/spreadsheet/ccc?key=0AocgA8O26ORNdEowY29oZWV2Q19FRkxxRjV0Y1RXcmc&usp=sharing
The idea:
- ESXi is loaded from a small thumb drive into memory.
- FreeNAS is loaded into memory from a local hard disk, connected to a cheap HBA.
- M1015 is passthrough'd to FreeNAS
- After waiting x seconds, other VMs are loaded from the iSCSI share from FreeNAS.
- Tuner card is passthrough'd to my VM running mythTV.
-> FreeNAS shares my files while MythTV serves TV for the rest of the network.
VMs:
- FreeNAS
- MythBuntu
- Debian or w/e for newznab, couchpotato, sabznd, ...
Thank you :eek:
Greetings
don't use iSCSI with freenas, use NFS if you want to go with that distro (the BSD target is BADLY broken).
You'll need to add a rescan/refresh in there as well to pick up the new storage if you do block - you'll need to add those commands to /etc/rc.local.d/rc.local.sh, NFS should pick up on its own.
Thank you for your reply lopoetve and you advice. :D
May I ask what you mean with "if you do block" ?
Greetings
Looking over your parts list it looks like you will have four total hard drive controllers, is there a reason for that?
How I understand your setup you are doing an all in one with all of your 3TB drives on the M1015 that will be passed to your storage OS, and then a small hard driver connected to ESXi as a datastore for the storage OS. This drive I would just connect using the onboard HBA of the motherboard.
You then have a cheap HBA, I don't understand the need for this one, will it be passed to an OS?
I'm just trying to understand this better.
Thanks
Thanks
I believe you misread, I will only have 2 M1015's as it's cheaper to have 2 of those than any other 16-ports controller. The cheap HBA is because my onboard controller isn't hardware raid, so I can't really pass that as a possible datastore. This is why I need a cheap HBA to just connect a SSD or w/e
Greetings
