Hello, had an issue come up and was wondering if anybody could help....
I had esxi 5.5 installed with a vm machine that I was using for local web development on an older Dell PowerEdge 2900 server and the power supply went bad....the 2900 uses hot-swappable redundant power supplies which I do not have an extra one.
Thought I would just try to remove the HD and use it in another machine.....esxi boots up and I can access using vSphere, but the vm says " Unknown Inaccessible" the datastore is no longer present.
Is there a way to recover that vm by using another machine?
Thanks!
Thanks!
