ESXi 5.1: Attaching disk with existing data
Zarathustra[H]
Extremely [H]
Hey all,
I have an external eSATA disk which contains existing data, that I need to be connected to a guest on my ESXi server.
Is there a way to have the guest access the drive directly, or do I have to create a virtual disk image on the drive and transfer the data to it?
I see the options in the add disk menu, but I don't want to experiment too much for fear of wiping the disk. (yes, I have backups, but getting them would be a pain)
Appreciate any imput.
As far as I know, you can pass any device directly. Does not need to be SAN storage. RDM is an RDM
Not true. RDMs require remote storage - can't do it with local. eSATA - depends on how it shows up, but I'd bet money on "local" so it won't work easily. You could pass through the port though :)
