- Oct 29, 2000
Hey all,
I started my first home ESXi (or I guess Vsphere Hypervisor, just to make it confusing) install this weekend.
It's running on a AMD E-350 rig. Right now I have two virtual machines on it (Ubuntu server and pfsense)
My original plan was just to play around with it, but it went so well, that I have already replaced my consumer router with pfsense in ESXi and am 90% of the way there towards replacing my linux server.
I'm realizing that I probably should have used better NIC's.
Currently I am using:
Broadcom NetXtreme on PCIe 1x slot:
LAN -> NetXtreme -> Virtual switch -> Management Console, Ubuntu Server and pfsense LAN side.
On board RealTek 8111C:
WAN -> RealTek 8111C -> virtual switch -> pfsense WAN side.
The broadcom chip isn't bad, but the onboard realtek chip stinks. I figured it would at least be able to handle the 30Mbit/s WAN (operating at 3% of its max bandwidth) which it can, but there are some strange latency issues over the interface.
So, as a solution, I just ordered an Intel two port EXPI9402PTBLK PCIe 4x card.
I envisage my future state as follows:
EXPI9402PTBLK x0:
WAN -> EXPI9402PTBLK -> virtual switch -> pfsense WAN side.
EXPI9402PTBLK x1:
LAN -> EXPI9402PTBLK -> Virtual switch -> pfsense LAN side.
NetXtreme:
LAN -> NetXtreme -> Virtual Switch -> Ubuntu Linux Server, Management Console, Potential future VM's
Onboard RealTek 8111C:
Disabled
The reason I am keeping the Linux server separate from pfsense, is because I run a NAS on my linux server, and occasionally data transfers are sufficient to completely fill the gigabit bandwidth limit. Because of this, I'd rather have it hardware switched separately, so that it never interferes with pfsense, and thus my contact with the outside world.
In other words, I don't want to - as an example - be playing a game online, and have someone copy a large file from/to the NAS and have that kill my game pings, even though the NAS access is not going to the outside network.
So I have a couple of questions:
1.) How does the above configuration and choice of hardware look to those of you more seasoned with ESXi?
2.) How should I expect the host to behave when I swap out the NIC's? Is ESXi good at auto-detecting new hardware, or should I expect a little bit of a challenge?
Much obliged for the feedback, and for helping out a virtualization n00b.
EXPI9402PTBLK x0:
EXPI9402PTBLK x1:
NetXtreme:
Disabled
