- Jul 2, 2008
I am trying to connect my macally T-S350SU http://www.newegg.com/Product/Produ...rnal_enclosure_macally-_-17-347-018-_-Product to an available esata port. My motherboard, a DFI 790GX-M2RS, does not have any native esata ports. I tried a sata to esata cable and powered the enclosure on before the computer, then turned on the computer. I also tried to use the external drive via esata when the computer was turned on before the enclosure. still no luck. The harddrive and sata ports work because I took out my 2ndary backup drive to do the test. I then tried using my nMEDIAPC ZE-C128 http://www.newegg.com/Product/Product.aspx?Item=N82E16820132021 which had a esata port. on further inspection, there was no esata host controller, so it was essentially like using the cable which I tried before.
Will buying a esata host controller allow the esata external enclosure to work? I don't understand how the sata to esata cable did not work, because sata and esata are essentially the same bus.
The reason why I am doing this is because I wanted to test my macally T-S350SU which I just received from newegg today. I am using the internal adaptor for an external harddrive project, and if the external harddrive doesnt work, I am going to return it.
I looked on DFI's site to see if there were any bios updates to address this problem, but there was none. Is there some special sata setting in bios that I have to set? I have the sata setting set to native ide mode. I don't have a raid setup, so setting the sata option to raid doesn't make sense. Is this some ahci thing? I am not sure.
Thanks for any help. I know this is a noob question, but I haven't used esata before.
