TechStuey05
- Aug 5, 2005
Hi, I have a Windows Vista Computer. I also have an NTFS External Drive that I use to store my data. yesterday I decided to run Error check on the external drive and it found errors on it.
After that it said that it was repaired and it said something about my files were moved to a folder or something but I missed the rest of the message. Does this mean that my files are not corrupt? Is there a way of checking?
One thing to note is that when I plugged my NTFS External Drive into my Windows VIsta computer, after using it for awhile I decided to safely remove it but it said that it was in use. Now I'm positive that I was not using the external drive.
I hit safely remove about 10 times but it kept saying that it was in use. So I decided to just unplug it. Could that have caused the errors on my external drive? Should I scan for bad sectors too?
how long does that usually take on a 2TB External drive? Any help is greatly appreciated
