Error with Cat 5.7
Shakezilla
So I just set up my new computer and installed the Cat 5.7 drivers(fresh nothig there nefore that) and now when the ocmputer starts up I get this error.
I click ok, and it pops up again then I hit ok. And its fine unless I try to open Cat control center then I get it.
Thanks for any help
tornadotsunamilife said:
This may seem obviosu but have you installed the MS .NET Framework 1.1?
I dont think so.... where can I get it
dont look down upon me cuz Im dumb :(
i have all my windows updates tho, but when I searched and it told me how to check to see if I alread have it, I dont see it. And I have all the windows updates so how do I get it?
edit: Found it you have to go to custimized setup for windows update.
So once I got that reintalled will I be good or will I have to run driver cleaner and reinstall dirvers?
edit2: I restarted and its fixed thanks a bunch
Yeah I was confused because I thought the .net would get downloaded with my other updates but I had to end up using the custom update one to search for it.
Thanks for the help
