Error installing PowerDVD on Win7
lone wolf
I just installed Windows 7 on my HTPC, and then Power DVD 7. I downloaded the updates and on the last one I got the error 2932 "Could not create file" I found one suggestion where it says to delete the folder at c:\windows\installer\xxxx-xxxx but there isn't anything at that location.
Has anyone had this issue?
I really don't want to upgrade just yet...and it worked great under Win XP
well for kicks and giggles I ran the installers in windows xp compatibality mode, and still getting this error 2932.
I was having problems playing videos in Win7 64bit. I ended up downloading GOM media player (cnet link), which is free to use and plays everything. So far its probably one of the best media players I've used. So I would suggest trying it out if you can't get PowerDVD to work.
I installed version 7 without issues, but I would suggest upgrading to version 8 or 9 unless you need the HD-DVD playback in version 7.
I have an XBOX 360 and HD-DVD drive for those if needed. So I pulled the trigger and purchased PowerDVD 9 and now when I go to activate it it says that I'm not an administrator, but yet everything in my account says that I am.
I will keep chugging away at this....
