Error in Printer Offline P4014
Are you using the drivers that came on the CD or the Universal Print Drivers from HP's site? How are you connected to the printer?
Delete drivers, delete printers and reinstall if you are currently using MSoft provided driver try manufacturers driver and vice versa
How are you connecting to the printer, USB or network?
What OS are you printing from?
Try the HP LaserJet Series II driver, it is for all intent and purposes a generic PCL5 driver (as PCL5 was created for the LJII). It is limited to 300DPI, single tray, and no duplexing but every HP laser printer since the LJII is backwards-compatible with that driver. The LJII driver is strictly for testing, if it works then you have a P4014 driver issue, if it doesn't then it is a printer/connectivity issue.
