Ergotron Neo-Flex
jackyyll
Does anyone know if it's possible to mount the Ergotron Neo-Flex (45-174-300) backwards.. As in mount the clamp the opposite way that you normally would mount it (The clamp opening faces AWAY from you) and just turn the arm all the way around and use it that way? Just wanted to see if anyone could answer this question before i bought one, because that's the only real way i could mount it on my desk.
I don't see why not,
I have one and it will rotate a full 360 degrees.
But, regardless of how the clamp is facing, be aware that the clamp should always be "behind" the monitor, so the arm comes from behind the monitor. It won't work if the clamp is closer to you than the monitor.
Kinda tough to explain, but take my word for it, as long as the clamp is behind the monitor it can face whichever way.
Regards,
10e
