Epox or DFI NF4
Justintoxicated
I have sceen some pretty good reviews on both of these boards.
I already have 2 gigs of C2 OCZ.
Which of these boards is better for the money?
Is the DFI really worth the extra cash?
I have used some epox boards in the past and they have been decent, however I think the one in my current rig may be going bad, if not the CPU...
I want a good board for overclocking, and can't decide between these 2.
I might do and SLI setup if it is worth it.
I like DFI NF4 boards, so far. I've had mine for a couple days (just got it booting and running for like 12 hours now...) Lot of tweaks and settings to play around with in the BIOS, and you can make 4 savable settings. Cheers!
The board I have ran me a little over a 100, like 102... not too expensive, imo!
-Adam
I havent used the nf4 version of any DFI board, but I will tell you that I am very satisfied with the DFI board that I have (ati chipset). The bios has far and above more options for ultimate overclock tweaking than any board I have seen. Extremely stable also.
unless you use bh5 or some other vx/utt ram, you are probably better off with the epox. dfi has more extensive bios, but except for ram timings and vdimm options the epox can do everything the dfi can do. you can also buy the epox sli board for the price of he ultra-d(which does easily mod to sli tho). epox customer service is average, but dfi customer service is only slightly better than an 18 inch nail thru your balls. i have owned both boards, and i have rma'd both boards. i am speaking from first person experience.
I have the Ultra-D and it's a great board. I've used Epox in the past in s754 and they're ok too. I'd get the DFI myself though :).
Well I already have the memory it is OCZ PC3200 C2 2x1gig
This still my board? Or should I get the epox, since i have the watercooling I may need all the FSB I can get.
When DFI Board is teh one to get? There are 3 flavors of DR and they all have the same specs! What gives? Just get the cheapest one?
I thought about getting the board that comes with 7800 for free, but I have a feeling I will be better off getting a different MB for Overclocking?
kirbyrj said:
Yeah, if your WCing, get the DFI over the eVGA.
Which one though? Which one has the newest chipset? There 3 different Nvidia NF4 DR's...I can't tell what is different except that one has an extra PCI slot and one has memory in a different location...
I want to get the right board.
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX
http://www.newegg.com/Product/Product.asp?Item=N82E16813136151
$195
DFI LANPARTY UT nF4 SLI-DR Expert Socket 939 NVIDIA nForce4 SLI ATX
http://www.newegg.com/Product/Product.asp?Item=N82E16813136166
$189
DFI LANPARTY UT nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD
http://www.newegg.com/Product/Product.asp?Item=N82E16813136157
$168
Which one do I want? I'm probably going to get an Opteron Processor does that limit my choices? all the specs look the same except for one has 3 PCI slots and the other has memory in another location (which does not matter since it is going in a stacker)
Expert is the newest revision of the SLI-DR and is the one you should get.
SLI-DR and UT SLI-DR are the same board with different sets of extras.
They should all work with opterons with no problem.
Are you kidding me? Have you seen the placement of the northbridge? Makes it nearly impossible to get an NB block in place, unless you custom-make one or buy a custom-fitted one.
I meant from the perspective of the voltages allowed and HTT's reachable ;). I wouldn't WC my chipset anyway, but I understand others would ;) Maybe a low profile cooler would fit in there.
So I can't cool the NB? I was not planning to do that unless the fan is loud....
Thinking about jsut ordering it from the egg, I think im definately getting my video card fromt here, Gotta pay tax though, but I know it won't take more than 2 days max since they are prettymuch local.
A common replacement is the Vantec Iceberq. Never tried it, but it has a standard 3-pin fan header minus RPM monitoring wire. Might work well with a resistor or something. My DFI chipset fan spins at 6200RPM FWIW.
Actualy I have one of those on the Epox I'm getting rid off I can just swap it out if need be. Mus tbe some way to watercool it though...
Thanks for your help Expert it is and 7800 15
Hope they are worth the extra $$
The Ice Burg stabalized my NB on the 8rda+, Was not stable @ 200 FSB with passive cooling...Plus the stock HS fell off lol
I think those small Koolance blocks would do the trick...only problem is they are 1/4"...not sure if you want to mess with that or not.
maybe a Y split would help flow? I'm the wrong person to ask though...I've never WC'd anything in my life :).
The chipset fan that comes on the DFI boards is a little bit loud, at least for my tastes. I replaced it with the Evercool VC-RE (i think that was it's name) vga cooler. It dropped my NB temps a few degrees and was noticable quieter. The fan only cost $7-9 bucks, so not bad at all.
I've since moved on to a EK chipset waterblock. The block fits between my two 7800GTX's with no problems. So there definatly are a couple of different options should anyone want additional/different cooling on the NB.
