ep45-ud3r internet problem
crazyboy515
i am unable to connect to the internet,even if theres a ethernet cable plugged in. this is my first build. i installed all the drivers that came with the motherboard. also the lights that should blink on the ethernet ports isn't even blinking at all. nor is it on. whats wrong?:(
Download the latest NIC/LAN drivers for your mobo off another PC and move those drivers over the new PC via a USB flash drive. Install the new drivers.
What OS are you using?
Are you sure you plugged in the ethernet all the way in?
I remember having this issue with my dfi nf4 ultra. I actually still run into issues with it when I reformat.
But anyways, like said above, make sure you update drivers, make sure you setup the network in network connections, reboot.
I say this, assuming that you are currently on your internet connection via another pc. If not, I would power cycle the router/etc...
The drivers that come with the mobo don't work on Vista 64, if you're using it.
Had me running in circles for a good hour when I first built mine.
