So basically the boards are the same? Like EP35-DS4 and just a normal P35-DS4? If someone bought a EP35-DS4 and just didn't install the software, would be just like buying a normal DS4?
Didn't want to create a new post for this but does anyone know if the Zerotherm NV120 would fit on the Gigabyte EP35 board? Looks like the NB HS might be a little too tall. I can't seem to find the dimensions for the board to see if there is enough to clear the 128mm listed for the NV120 (128x95x150mm per the manual). I want to make sure I can point it towards the back of the case.
Thanks![]()
