I have a server that went to hell last week and I plan on using my old HTPC setup (e6600, 2x1GB Ballistix, P35-DS3L) to replace the old server hardware and build a new HTPC setup. Normally I'd just get an A2 240, 2x1GB ddr3, and a Gigabyte UD2H or even an Ion setup for a nice low power setup. The problem I'm running into is that I plan to be using that to LAN against my girlfriend with SupCom, SupCom2, and WoW at 1680x1050 so it actually has to have some gaming potential.
I currently have an Ati 3850 which works fine, but it has a pretty high idle wattage and I'd prefer to keep the whole system under 100 watts if possible. I don't think switchable graphics are available yet for desktop which would've worked perfectly for this issue.
So what do I do? WoW is mainly CPU bound so a 2.8 regor would be fine, but the graphics will suffer badly. SupCom is pretty heavy on both CPU and GPU which would kill the IGP badly.
Should I use the IGP and turn down the graphics or is there a discrete card that is low power and will give me good enough FPS?
