EMIII needs a points database update???
upriverpaddler
The points showing in EMII dont seem to be matching my [H]ardfolding.com stats. Anybody else notice this?
EMIII usually updates when it's started or after a WU is turned in. It gets the stats from Stanford which updates more often thn the stats sites do. Most of the time, EMIII is the same as the stats sites or a little ahead of the stats sites until the next update in which they usually match.
Double check the Stanford site for your stats and see if it matches EMIII. In most cases EMIII should be the same or a little bit ahead unless EMIII has not updated to the newest points total. If it's been a while since EMIII has been updated, shut EMIII down and restart it. It will get the current points total from Stanford then.
You can also just double click on the points rather than closing and re-opening it. With a lot of network'ed borgs it takes my EMIII about 10 minutes to open so doing it to just update my points would be a real bummer.
I have found that double clicking on it does not always update the points. There have been times when my stats have been updated but EMIII wasn't. I double clicked on it to get the updated stats and it would not update them. I would shut off EMIII and restart it and it would grab the new stats then.
I think he's talking about a protein by protein basis. I've noticed proteins that EMIII claims to be like 150 pts will only yeild like 60 (no early end). I think Stanford has changed some point values and EMIII just need an update.
Fold on people! For tuxedoedShrimp
Larry updated the protien file on 12/20... you may want to stop by and pick it up....
Keep on Folding!!
