Was at futureshop today and picked up an open box Emachines slimline system for $150, quite the steal:
Athlon 64 2650e
Some MCP61-P AM2 M/B
1GB DDR2-800
160GB Seagate 7200rpm
Geforce 6150se Integrated video
Windows XP Home Edition for Nettops
220W PSU
14A on the 12V Rail
So as you can see not much of a config and i've got a few questions.
For the motherboard is says "boxer 61 DA061" Its an AM2 mobo and has 1x pci-e 1x slot, there are traces where a pci-e 16x slot would have been.
At first I thought the M/B was matx however looking at it further its either dtx or mini dtx, meaning the only motherboards suitable for replacement would be mini itx
According to emachines website it supports Athlon 64 X2's (45W) and semprons, now heres my first question:
i've seen in various oem systems built with the geforce 6150se motherboards and have had various phenom cpu X4 and X3 (b2 b3 steppings) so i'm curious to see whether or not those particular cpu's would be supported. Ideally i'd like to throw a 905E X4 of a 705E X3 in there if possible (doubtfull) but I could also settle for a 9350e if it doesn't support PII (Newegg has 9350's for $105)
As for the use of this system, not to sure yet, will prolly end up as a HTPC or a small mini workstation. I know some people will says go with a dualcore of some sort but i'm used to multicores now so there is no turning back.
If using the motherboard isn't an option i'm thinking of going with the Zotac AM2 board along with a PII of my choice. I mention the AM2 itx because I don't really do much in the form of gaming but I suppose I could go all out and get the 775 itx zotac board with a Q8200 or something, as long as they aren't too power hungry, I guess I should mention I want this to be as silent as possible.
Any thoughts
Athlon 64 2650e
1GB DDR2-800
220W PSU
Any thoughts
