Ok, so I pulled the trigger on another 8800gt, but I'm out of monitors (not counting the old 21" CRT which I'm not turning back on). This means making some of those neato DVI dummy plugs. Are these the correct resistors: http://shop.vetcosurplus.com/catalog/product_info.php?products_id=8083
Will any type of tape work to hold them in, or do I have to use electrical tape?
Anything I should watch out for so as to not set the apartment on fire (you know, aside from running 5 machines and 4 GPU's 24x7 in a 10x10 room)?
