Electricity bill - 2 350watt comps
Just wondering in what area of an increase in cost running 2 computers 24/7 each with 350 watt psus. (no monitors, they're just fileservers/lan game servers)
I live in northern CA, just in case any of you live here too :)
thanks!
Got 6 100 Watt bulbs and leave em on. That's the same energy. Considering of course that you have PSU's maxxed out all the time.
I'd be willing to bet it would be closer to the equivelant of leaving a single 50Watt bulb on all the time.
For comparison, I have the following:
My main system w/ 500Watt PSU, dual 21" monitors, all-in-one printer, tons of USB stuff
My wife's computer, with 350Watt PSU, 17" monitor
My HTPC, with ATI AIW 7500, 350Watt PSU
My filserver, with 400Watt PSU
All of that is on 24/7 and I saw no increase whatsoever in my bill.
Oh yeah, and I almost always have another system running on the workshop table, that's hooked to a 21" monitor.
At a guess you will use around 300 watt/hour.
7.2 Kw per day or around 200 Kw per month.
At 5c per Kw its 10$ per month.
My systems use 1.5 Kw per hour.
At 5.4p per Kw thats around £60 per month.
But they do keep the cottage warm....:cool:
Luck.........:D
i have 2 roomies sharing a house. i have my comp running 24/7, my other roomie does, and my other roomie has 2. then there's the htpc in the livingroom [it goes into ps saving mode tho] and the other out in the livingroom. our electric bill is never that high... out heating bill this winter tho... ::gags::
I had 525 KWH with my computer, the light above the computer(which has 5 bulbs), use of heater, microwave, oven and other lights/crap.
I left my computer on most of that month, this month I turn it off at night, seeing if it shortens my bill.
But my bill was $41, not bad.
eek, well hopefully my parents won't notice/care about a uh, $40-80 difference next month :D I'll just tell them they're super firewalls that will block out any hackers, they dunno crap :)
Consider this when it comes to cost though:
The amount of power that an electrical component uses up, is almost completely turned into heat. So although this power is used, you actually will be heating the house with this, so it's almost no cost what-so-ever in the winter time (or all the time if you're in canada like me...hehe).
But the other thing we need to consider is the fans. A general approximation (but not a rule) is that to disipate the heat produced from the electrical component, you need about the same amount of power in the fan. This power is completely lost however, as it is turned into kenetic energy and sound.
So while this doesn't give much in the way of numbers, it is something to be intrigued about.
Just make sure you turn off the monitor when it's not in use :) If it's a CRT, it's the biggest sucker of energy :D
I don't know how much your electricity costs are in kw/hours or anything like that but I'd be surprised if you ran the electricity bill up $5-10/month.
Since you don't have monitors on the systems, it makes a big difference. I wouldn't be surprised if monitors chew up more power than the rest of the system.
btw, ignore any typos or anything like that in my post. I'm a bit drunk right now and getting ready to hit the sack.
Here it costs about $15 a month on the power bill to run my 5 monitors and the computer.
i had a friend do an experiment... he left his computer on for a month 24/7 and then a month with it off when he wasn't using it. The electric bill was 7$ more when leaving it on all the time.
I have two 250w systems on all the time with a dell on occasionally at night and my bills not very high..
you should be fine... and not see a 1000 dollar electric bill..
Luck.........:D
Saying your system draws 1.5 kilowatts per hour doesn't really make any sense. The KWH unit is convenient for billing, but it really doesn't mean anything when talking about power draw of a device. And it is a kilowatt hour, not a kilowatt/hour. It is a measure of how many kilowatts were used TIMES number of hours of that draw, not power draw PER number of hours. Suppose your computers draw a total of 10 amps. 10 amps X 120 volts is 1200 watts, or 1.2 kilowatts. They are continuously drawing 1.2 kilowatts. That doesn't just add up to 1.2 kilowatts over the hour. When looking at how much power a device draws, you want to look at how many watts it draws, not how many watthours it uses. Then when you want to know how much power you have used in a week or a month or whatever, you use watthours. You look at how many watts the device draws and you multiply that by the number of hours it was drawing that much. Therefore you get watthours. If your computers draw 1.2 kilowatts, then if you leave them on for 10 hours you get 12 kilowatthours. So what I am getting at is there really is no such thing as watts/hour. A device can draw a certain number of watts for a certain number of hours and that is watthours.
Well, it's a little more complicated than that because a Watt is really a Joule/Sec, so it's not a quantity it's a rate. A rate x time will give a quantity, such as a KWH. Dunno if that clears it up better or not
Shut them down when you aren't using them? I mean have a schedule for your server. I mean are you charging or anything like that. If you are providing a good server, and its not on ALL the time than people usually understand if its free.
I don't host, so my machine is OFF when I am not using it. My Monitor ISN'T an energy star, well thats because its an 8 year old Philips 107B. I intend to upgrade quite shortly. Viewsonic Pro 19" CRT.
Cheers,
As for heat... if the genmay folding guy is right in his calculations and I'm right in mine, then a sole monitorless computer that converts all energy input to heat can theoretically raise the air temperature in a 4*4*2 room over the course of an hour by 15c.
That's assuming a) Perfect transfer of energy to heat, b) perfect insultation of room and c) perfectly 0 air flow.
If there's so much as 0.1m^3/s of airflow through the room, then you'd be hard pressed to raise the air temperature by 1.3 degrees over the course of that hour. Given that rooms are not perfectly insulated and that a computer does not convert 1:1 energy to heat, then heat is unlikely to be much of a problem unless you absolutely seal and insulate the room.
:rolleyes: All the math in the world cannot compare to acutal experience, especially since there are far too many varibles to consider when making sweeping generalizations like that. Some processors run hotter than others, there are different heat outputs of various PSUs, etc. But I know that in my room I have 2 computers, see my sig, and they can substantially raise (>5 degrees fahrenheit) the temp of my room in an hour of operation.
this is true, my apc va350 will die in .5 seconds when the moniter is plugged in. with out it, it runs fine, of course i cant see anything, so when i go on battery power, it hibernates after 1 minute
There's actually not very many variables at all. If you consider an arbitrary microprocessor, and can calculate the amount of energy that processor uses up (easily possible), then you can be assured that all of that energy is transfered directly into heat.
The only other variables to consider is the amount of mechanical energy used in fans and drives.
When it comes down to the energy side of things, all a microprocessor is is a very expensive heater.
Why wouldn't there be 1:1 energy to heat transfer? Where else would the energy be going?
There is, but such a unit is not often used, since it has little practical application.
Light, sound, kinetic dissipation i.e. vibration travelling through the case and being absorbed into the floor, overcoming inertia in drives, friction in moving parts etc etc. Friction is not a 1:1 energy conversion of kinetic to heat either.
Even a perfect electrical heater cannot convery 100% of it's input energy into heat. A computer is far from a perfect heater.
If however you have designed a device that can convert electricity to heat in a 1:1 ratio, there's a few scientists who'd like to know :)
You'll use more electric for having two monitors on all the time then two 350W computers.
and at idle they're only pulling maybe 1/4th of their max rating so, no bigs. Just puta 1minute timer on your monitors to goto sleep when you're afk..
I hate to break it to you but unless all my professors are wrong, electric resistance heaters are DEFINED as being 100% efficient. It's nothing new. About the only time you'll ever see a 100% efficiency rating though.
And all that noise, light, and sound turns into heat eventually too. Same with friction.
As for heating the room, IF the room is well insulation (Qout=0), then the only difference between a room with airflow and without is in the dispersal of heat. The room with airflow will simply spread the heat around the room better.
In my dorm room (my computer, roommate's computer, 2 big CRTs), I can feel a really big temperature difference when we leave them on with the door closed for a while. Even if the windows are open (granted, our windows don't open very well)
so how much energy does a monitor use in standby mode? should i push the power button on the front or let the turn off on their own?
Monitors do use some power in standby(they need to be able to receive the signal to wake up) but that amount is pretty insignificant compared to the power used when it is displaying something. A lot of monitors don't even cut the line voltage when you push the power button so they are still drawing a bit even when the monitor is off. If the symbol on the power button is a circle with a line inside it then the line power is completely cut off. If the symbol is a circle with the line half in and half out of the circle then the line power is not cut off and some parts of the monitor are still powered even when the monitor is off. That's probably more than you needed to know, but it is interesting nonetheless.
They still use a bit, not sure the exact figure, but look at it this way. The monitor is the last thing you look at when your leave the computer, if you can't reach up and touch the power button, you have other problems.
Don't use the power saving feature, I'd bet you waste more power by using it than the power switch (you just won't forget to turn the monitor off in most cases). A 1 minute power save setting is just making you rely on it. Granted it's being a little anal about power, but hey that's the topic...
I always turn my monitor off when I know I'm not going to be at the computer for a while. I still have the power save delay on just in case I only plan on leaving the computer for a couple of minutes but turns out to be a bit longer than that.
My point is that it is ARBITRARY! There are more devices in a computer than just the CPU, and since people aren't running the same microprocessor, you cannot easily even make a generalization about a computer based on saying "2 computers with 350w PSUs"!!!!
But you can assume that most computers have one optical drive and one hard drive, and you can pretty much assume all brands throw out similar amounts of heat (it ends up not mattering too much compared to the proc), so the major heat sources are the proc, vidcard, and RAM. Taking "average" values of everything else (heck, you can even average the vidcard and RAM if you like) gives a decent prediction. At least, within $5 of the monthly bill.
it's better to have a guess with a huge standard deviation than no guess at all.
Admittedly, the two photons of light that escape my computers led out my window are not converted to heat in my room, but realistically, those two photons don't count for much. All the light that stays in my room does change into heat eventually. After all, energy is conserved, and it doesn't stay as light forever, as can be seen from the fact that when you turn of the lights in your room, it gets dark. The kinetic energy also gets turned into heat through friction. Again, some of it escapes my particular room, if it travels through the floor or something, but the bottom line is that all the energy created by the computer gets turned into heat.
As far as criction not being a 1:1 conversion of energy to heat, well, it sort of is. No energy is lost; it is conserved. And if friction causes all the kinetic energy to be depleted, then it all changed into something else. That something being heat, other forms of kinetic energy (sound, which then gets transfered into heat leater), etc. But everything ends up eventually as heat.
hahaha, that made me laugh.:D
"(or all the time if you're in canada like me...hehe)."
Sigh, I know its just a joke but these Canada statements really get to me sometimes! Ontario, Canada here, and we can get up to 45C during the summer. Which is probably around 120F for the Imperial System.
