Are you guys familiar with those black plastic paper/sheet that they put in laptops in areas that can potentially short out from 2 pc boards touching.
An example would be a laptop motherboard where the sodimm ram is plugged into the board. They usually have this plastic material that is placed between the ram and the board and it prevents the two from shorting out.
Hopefully you guys can get me the name of this or know of a place that sells this material.
