I ordered a XFX 6970 HD697ACNFC. According to CoolingConfigurator, thmI'at is a reference design. So I ordered this block.
My card's packaging does say HD697ACNFC. But if you look at the back of the card, it sais HD697ACNFC v1.1
v.1.1???? WTF?
The AMD logo is gone above the PCI-E lane, but otherwise the PCB is almost identical... I say almost, because the two bottom screws under the memory are further apart. Did XFX secretly make a new revision of their reference design and didn't tell anyone?
Now the block won't fit, I'm out 120$ and there doesn't seem to be a block that exists for that supposedly 1.1 design?
v.1.1???? WTF?
