ECS KN1 Lite SHUTTING OFF PROBLEMS
okay heres a list of what I have
KN1 Lite Motherboard (with newest bios update)
using the On Board Lan, and Sound, USB
I have a PCI-Express NVIDIA Geforce 6200 LE with DVI & VGA
512 Megs Of DDR400 PC3200 G.SKILL Memory
1 Lite-On DVDRW Drive
1 HP DVDRW Drive
1 WD 80gb IDE Drive
the problem I am having is, i can be on the net, playing a movie anything really, and it will just SHUT off, no shutting down or anything.. I have CPU Temp shut down off in the bios, I have tested the memory (nothing bad), so I was just curious if anyone has heard anything about this with this motherboard
thanks
Is your power supply flakey? Sounds like a power issue if you get no beeps and your memory checks out fine.
Thermaltake 440 watt psu, works perfectly, tried 3 different power supplies!!! I but I finally think we have it figured down to the USB, I have alot of USB hard drives and for some reason.. the BIOS fix didnt help.. so I disabled the onboard USB and got a PCI card.. hopefully it stays stable if not BACK TO FRY'S
AND TO LET YOU ALL KNOW, DO NOT BUY @ FRY'S NEVER EVER EVER!
thanks
zero
