ECS K8T890 Unknown Processor
eurin
I'm getting this error for an Athlon 3500+. I can't reach the bios. The support on their webpage sucks, and isn't quite clear on the bios flashing boot disk. Has anyone been able to fix this problem? I think this error may keep me from even updating the bios.
I bought this combo two months ago at Fry's, but I was using the processor in another system until now. I don't think Fry's would let me return it in exchange for another board. My other option is to ebay the board.
Any help or suggestions is greatly appreciated.
So, can anyone tell me how to flash the bios with this problem?
Try taking the board into fry's and tell the guy that runs the bench @ returns to just use a 3200+ or something and hand him the disk with the bios files on it and tell him it's your last chance. He might flash it if he get's approval from the sup, or maybe you can borrow a friends 3000-3200 chips just to flash the bios. Have you processor there too so he can test it after the flash.
Do you have a date for that bios? I can't imagine why it wouldn't show up properly seeing as the K8T890 was late to the table and well after the Venice cores were launched. There maybe a bigger problem than just a bios flash needed.
I just went to ECS's site and the flash procedure for both Windows and DOS are clear. You may want to read them and then follow the instructions closely (depending which method you use). If you can verify, do that to see which BIOS version is currently on your board. From ECS's site, the latest one seems to be the 051220 (dated 12/28/05). Yours may be the 050928 (dated 10/13/05, which is somewhat old). Use the 051220 version for best compatibility. Good luck!
