EATX12V Connector Help
CorpX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
That's my power supply and I'm trying to hook it up to an Asus P5Q Pro board.
PSU has 2 wires coming out labled "CPU 1" and "CPU 2". Mobo manual says
"Make sure to remove the cap on the EATX12V connector before connecting an 8-pin EPS +12V power plug.
"Use only an 8pin EPS +12V power plug for the EATX 12V connector"
So, what should I do?
EDIT: Basically the same question as this guy, and they're saying to plug both in.
See the cable marked "CPU Power Connector: 4+4 Pin" in this picture?
Plug that into the 8Pin EPS port on the motherboard.
