Easiest Way to Remove Nforce4 Drivers
Skrying
What's the easiest and most clean way in removing Nforce4 drivers? If Driver Cleaner what filter should be selected if the computer is also using a Nvidia graphics card?
Thanks.
driver cleaner should have an option for the nforce drivers. i am not sure of the exact name used right now, but it should be in there :)
be sure to do it while in safe mode
Thanks.
Most recent nVidia drivers have a very good uninstaller that will remove the drivers from your o/s pretty cleanly.
However if you want to be double sure that all traces are removed including unlinked files in your Windows system directories, get driver cleaner and tick the 'Select multiple filters' box. Then select anything that says nVidia and let it run.
Tips:
* use Cab cleaner on both cabs so that Windows won't try and load any stock drivers when you remove your current drivers.
* Unplug or disable your internet connection while updating your drivers. Windows XP WILL try to fetch WHQL drivers from Microsoft wether you have auto-update enabled or not. It will do this without your permission and can be quite annoying.
The only problem with Cab cleaning is that it also removes the default Nvidia/ATI microsoft driver that comes with Windows which is useful for older versions video cards (TNT2, Rage, etc).
