Easiest way to recover data...
SilverSliver
Well, my fathers computer kicked the bucket. I believe it's the Mobo -- gets about half way through loading the bios and just locks. Resetting cmos doesn't work, different ram set-up's don't work. Just borked.
Anyhow.
I'd like to get on the drive somehow and get his Quickbooks file from it. He's had an automated online backup service, but apparently is wasn't configured correctly and kept backing up the same identical file, over and over again -- so he's lost all records kept since January.
What is the easiest way to do this? Should I try and pick up a USB enclosure? It's an IDE drive. Also, is any software required? Thanks.
His computer was running XP. I am running 64 bit Vista.
just grab an enclosure or a usb adapter i have two of these and they have saved my ass and few other peoples too
Just use that adapter, plug it in, and I should be able to navigate the file directories as needed?
Will it allow me to run Quickbooks on that drive, create a backup file, and then move the backup file off the drive without using recovery software?
Unless the software is extremely poorly designed, it should work fine.
Or skip the enclosure if you have another computer and temporarily hook up the drive to it.
Don't have to slave the drive?
If the drive from the failed machine is a standard 3.5" ide or sata drive, or a laptop sata drive plug it straight into your desktop computer. If it's an ide laptop drive you can get a cheap adapter like this. Also if it's an ide drive set the jumper to slave or cable select, if you are going to be copying a lot of files and it's an ide drive put it on a separate cable if possible.
Start up your desktop computer and make sure it boots from the drive that is normally in that machine, most motherboards have a function key you can hit when it starts up that will take you to a boot menu.
Once the os loads it should just mount the drive from the failed machine as another drive letter, then copy off those files you are after.
Oh and make sure you either install the drive in the machine or have it sitting on an anti-static bag before you turn it on, many people fry drives powering them on when the circuit board is sitting on or leaning against a metal case or part of the frame.
Slaved it, went into my bios -- wouldn't recognize that a drive was attached. Windows didn't see it either, unfortunately. Will wait for my USB enclosure to come in and try that.
Sorry, if Windows doesn't see it, more than likely, it's done.....Although, I've seen BadBlock give some solid advice.
Maybe he can help.........
If all else fails -- is here a data recovery service anyone can recommend -- and how reliable are they in general?
I've never really had data I wasn't readily able to backup, so not much experience with trying to recover what may possibly be a dead drive at this point.
Like Old Hippie said, if your motherboard can't detect it, then it is unlikely adding an external enclosure will help as that is just adding another (usually crappier) controller between the motherboard and the drive.
Try disconnecting all the drives in the machine except for the problem drive, set the problem drive to cable select, boot up the machine and immediately go into the bios. Go to the device list screen in the bios (usually the first or second option) and see what it says. It will either list the drive correctly, show no device detected, be blank, or have garbage data showing the wrong drive family or some crazy capacity.
Also listen to the drive (hard to do with fans nearby) and make sure it is spinning up, that you can hear it read a little 3 seconds or so after it powers up, and that it isn't making some kind of repetitive clicking sound or spinning back down.
So you hear it spin up, then a clunk, then it spins down or does it keep spinning but you never hear anything else?
I take it the bios can't detect anything or gets stuck trying?
Also what is the manufacturer/model of the drive. And was anything changed prior to this happening (hardware moved, lightning) or did someone just try to turn the machine on like they do every day and it wouldn't start up.
If the drive is mechanically dead, meaning either the drive mechanism itself or the electronics involved, forget it, you'll never get data off it yourself. As long as whatever the drive is plugged into can't "see" the drive or access it in any way, that data is long long gone. Your only hope would be a drive recovery outfit like DriveSavers or perhaps OnTrack Systems, the real pros. They'd have to take the drive apart to do the recovery, and that expense would probably be several hundred bucks if not more.
Decide how valuable that data is and proceed from there. But as long as nothing is detecting the drive being connected, you as a home/end user will never get data off it. :(
Folks were at there weekend home, computer worked when they left. Came back on Monday and it wouldn't get through bios.
I tell my mobo to auto-detect a slave drive, and it doesn't spot it.
Seems like it spins, clunks, then stops.
It's a WD400.
Unfortunately Joe Average is probably correct. If the drive spins up, attempts to do a read, then spins down that usually means it tried to read the system area of the disk, failed, and gave up. Which means the system area of the disk was corrupted (not likely) or the drive has experienced a physical failure.
Some of that family of drives will have a part number near the middle-left of the sticker indicated by "wd p/n:" or "mdl:", I hope for your sake the drive you have doesn't begin with WD400BB or WD400EB as these are notoriously annoying to service. For some unknown reason western digital decided to attach the head stack (thing the read-write heads are attached to) to the lid of the drive, which has to be removed to replace any internal parts. Fortunately they stopped doing that but there are a lot of those drives still out there.
Hey now, let's cut our new friend BadBlock some slack. :D
His sig, SparrowData, indicates he's one of the pros we're talking about.
He's been giving some solid advice, here and elseware, and being the nice friendly guy he is, will probably give a little discount to those who need his services......Ahhhhh, right BadBlock? :) :D
I wasn't going to say anything, but since you brought it up. :)
I normally try to steer people away from data recovery companies altogether, because in some ways many are kind of like antivirus companies in that they try to create fear and make people think there is a lot of black magic involved in every recovery. When in reality many, if not most, people who have a problem with a failing drive have a window of opportunity where they can get the data themselves if they are comfortable with computers and have some decent guidance. I am talking mainly about logical failures (deleted or corrupted files), or minor hardware failures where the drive is still mostly operational.
The companies Joe Average mentioned, Ontrack and Drivesavers, are the giants of the data recovery world. They have a large staff and a large stock of replacement parts to match with damaged drives and are well equipped to deal with extreme cases like fire damage, flood, etc.
That said, they also have a lot of overhead and price accordingly. I don't speak for them and they don't typically give you an exact price until after they have done the work, but the people I have talked to who have used them and other large recovery companies have said that typically there is a $100-$200 "attempt fee" or "initial evaluation fee" that you pay regardless of outcome. And after that for a single drive physical damage recovery the range is usually $500-$2500, with your drive (just a guess) falling in the $800-$1200 range.
If you want hard numbers you need to call them, and they will probably give you a range. You can also Google around for something like "drivesavers charges" or "ontrack charges" to get an idea of what other people have paid for similar recoveries.
Then there are the smaller companies like the one I work for. The advantage of the smaller ones is they usually charge less, and sometimes will offer more services or be more flexible with specific customer requests. The disadvantage of the smaller companies is there is no name recognition so they are harder to judge, and they are often less experienced with extreme cases. For example if we get recovery requests for severe flood or fire damage and there is a very low chance of recovery we often won't even accept the initial job since we don't charge for evaluation and would be just burning time in many cases. Whereas the big guys will take anything because they get paid regardless.
I'm not going to recommend any particular company as different ones are better suited to different jobs. You need to ask yourself things like, is data unique or can you recreate it? can you live without it? if you do need to recover it how much is it worth both in terms of money and in time? Once you have those answers you can proceed. One piece of advice I would give if you do decide to recover it is stay away from the chain stores, especially places like Bestbuy(Geeksquad). This is just my opinion but places like that generally are not equipped to deal with much beyond running an undelete program and when they are given drives with physical failures will often either charge for nothing, make things worse, or will hand it off to some other 3rd party data recovery company and put their own fee on top.
There ya have it.
It's a definate plus to have somebody onboard with hands-on experience in mechanical HD repair.
The prices on your website are definately lower than the 'big boys' and within the reach of the average Joe if the lost data is irreplaceable.
Because I'm self taught on computers, I've had many situations involving lost data and my recovery skills have become pretty efficent....they had to! :D
There's no black magic involved and most here would feel confortable attempting recovery with a little encouragement and a push in the right direction.
I vote SilverSliver send his drive to BadBlock and write a review. :)
