What kind of ram do you have?
E8400 for sure. If you were the type of person who would benefit from the quad-core, you'd know it.
I guess for me the question is not which of these to buy but why anyone would buy anything other than one of these. Can't believe the value of these processors.
Still not sure where to go with this.
$50 less for the E8400.
I doubt I'd do a lot of multitasking.
is the E8500 or E8600 any faster than the E8400?
I download lots of porn
for "future use"
It seems iffy if newegg has G0 stepping on them or B3.
Anyone ordered one recently and know?
Or can anyone confirm a place that does have G0 Q6600's?
IF there E8400 weren't sold out at Fry's I'd probably go with that.
I got my q6600 a month ago and it was g0, I'm pretty sure g0 is the only one left by now.It seems iffy if newegg has G0 stepping on them or B3.
For me the main reason NOT to pick up any current Intel quadcore is because they are not true quads, they are duals on the same pcb... Personally, I don't like this engineering decision, although I'm sure there are plenty of good reasons for it
Ok, but by your logic then you shouldnt like their Dual-Core chips either. After all a Core2 Duo is just two cores on the same die that shares the same block of cache, etc. Its not as if it is two independent cores with two independent blocks of cache, etc.
A Core2 Quad, being more or less two C2Ds on one chip actually suffers less from this issue if you think about it. While the two cores on a C2D have to share a single block of cache, a Quad has two blocks of cache among the 4 cores to work with. If you were running something that only took advantage of two cores, each core that is being used might potentially have access to its very own block of cache on a quad. So while a Core2 Quad might not be a true quad, its certainly more of a true dual than a Core2 Duo!
I don't dispute that current Intel quad-cores are made that way for a good reason and it's only my PERSONAL opinion that multi-die solution sucks, end of story.
Actually, it's not my logic, it's yours. I think I was clear enough - I don't dispute that current Intel quad-cores are made that way for a good reason and it's only my PERSONAL opinion that multi-die solution sucks, end of story.
maybe Intel can hire you to design their cpus. Show them how to do it...
Why does it suck? No reason in particular, just felt like throwing that out there? I guess it's possible to have opinions with no basis in fact but I don't know how that would be helpful to the OP or anyone in this thread. If there is anything specific about the Core2 Quad design which you don't like feel free to enlighten us. I'd love to hear what about the C2Q not being a "true quad" makes it less desirable than a C2D (which if you've forgotten, is the topic of this thread).
Man i wished i had a dollar for everytime someone post this same question. Wonders if anyone even uses the search function anymore.
Simple logic stands in the question.....
Q6600 if you do encoding , big rar files, music etc.
E8400 if you just do regular things on your pc.
Good Day
Is there any reason I will regret buying a Q6600?
I don't usually upgrade my PC every year.
I upgraded the CPU is this once since I've had it in the last 5years. from a 2.4Ghz P4 to a 3.0Ghz with HT.
Any suggestions where to buy the Q6600? Any place guarantee G0 for under $200?
I'm so clueless with what to go with right now.
I understand the arguments, and that e8400 is better for gaming.
what I don't understand is which will last me longer.
Btw G0 is best stepping for Q6600 and E0 is best for E8400 correct?
Also, Fry's is out of stock on their E8400, so really only a $20 difference with these procs?
