So I have an e7200 that I've been tweaking every so often to get maximum performance. I have it stable at 3.8 with 1.352 volts (10 passes IBT). That is with 9.5x400. What is the benefit of lowering multiplier and raising fsb? Is it possible to get more out of the chip? I have an asus maximus and i know that it will do well past 500 fsb. Is it possible that a configuration like 444x9 would be possible? I've tried 421x9.5 to hit 4ghz but my temps get to like 73c in IBT and it fails. Voltage is 1.425 which is higher than i'd like. So what should I do? I run my northbridge voltage at 1.4v, memory at 2.1v. Everything else is set at auto. Thanks!
