E6850 & Bad Axe 2 (BX2)
Rockmore
:rolleyes: Can anyone worldwide confirm whether or not the upcomming E6850 release in July will work and be fully compatible with Intel's BX2 motherboard?
In 4 fully documented email contacts with customer service, tech support, and pre-sales, Intel was EXTREMLY RUDE and completely refused to confirm or deny that the BX2 would or would not support the E6850 (through bios updates, board changes, etc). They would not deal with the issue at all, and would mostly played down the current features of the present BX2 only suppoting 1066fsb soley.
(We realize other boards like the Asus P5B deluxe with latest bios will support the upcomming E0 series processors, but as total trash and bad QA as Asus is now, Intel should be the first source for decent motherboards that supports their own processors...).
Thanks
Customer service normally isn't in the habit of giving you advice on products that aren't going to be released for several months. I'm sure they could be nicer, but I'm not surprised they didn't tell you anything.
Anybody credible over 20?
This is not a common 'customer service' problem or response. See original post- this was MANILY with tech support and pre sales.
Still need to know if the Intel Bad Axe 2 (BX2) will support the E6850.
i know that this does not answer your question, but what the hell difference does it make?
i'll will take a guess - you want to buy a board now, and use it for this particular cpu later?
are any other manufacturers guaranteeing compatibility with this cpu? could it be within the realm of possibility that they are not sure? could it be that there will bw a bad axe 3?
Need to bump this up- now that the Etards are through being completely off-topic. Please see ORIGINAL post. :eek:
Thanks
At this point, no one outside of individuals who have engineering samples of those chips could tell you for sure. I'm not surprised you got no answers out of Intel's customer service department. Typically those individuals aren't going to know the answers to questions like that about unreleased processors.
