You might want to dial down the voltage. The max recommended voltage for a C2D CPU is 1.55V I believe. Anything after that means damage to the CPU.
It was a suicide run.
I'm tempted to try that heh
I got mine to post at 3.9ghz at 24C room temp and stock voltage... wonder what a winter cooled room + some insane voltage may do heh...
