Moddest Mouse
- Jul 19, 2006
whats the best mobo for the E6600 Core 2 Duo? please post the price too
Vlad_13 said:Abit AB9 PRO![]()
that makes a surprisingly intelligent pointMase said:I opted for an Asrock 775dual-vsta... why when I can afford any mobo out there?!
Its just knowing how us early adopters will be drooling over the next crop of Conroe boards,
and not wanting to drop ANOTHER $200+ on something we would rather have,
that makes this $57 place-holder well worth the money...
I'm not nuts or really feeling any of the options out there right now.
Some revison 2 mobo's with some bling are right around the corner yo!
kirbyrj said:Personally, I'd go with the Intel 945 chipset version The XFire Conroe one looks like a better board than the Dual VSTA one since it's Intel chipset vs. Via.
I dont think that chipset can take it ,anyway after i read the review on anandtech on overated memory i told myself no. The performance peek is at about in betwwen 667 and 800 after that you loose a lot for next to nothing performance.The performance increase is about 3-6% and you pay a extra £100-150 for it.A tight DDR800 is good enough at a time like this , yes when they become cheaper then yes buy it but only when its very near to the ddr800 price. The bandwidth increase on intel and amd are two different things.Ikarius said:I'm also looking for a mobo for the E6600, but my real question is whether or not anything in the current crop of SLI boards properly supports the 1066 mhz FSB. If I buy an Asus P5N32-SLI SE and some Corsair XMS2 1066 memory, is that memory going to run full speed in the mobo, or will that really only run full speed in an Nvidia 570/590 chipset mobo? Reading the specs hasnt yet told me much, as it appears that every place I go writes the specs up differently- I've got no idea which the real story is....
--Ikarius
I have two core 2 duo , one is my nephews which i made and overclocked to 2760mhz and is a E6300 and i got it from Scan PC in the UK in bolton.Moddest Mouse said:thanks i was thinking about getting some 667 ram to, wat core 2 did you get and where is it at and what changes did you make?
When I was looking at that board it was only $10 more than the Dual VSTA. I'd pay $10 extra for a placeholder, but maybe not $25.Mase said:Why spend an xtra $25 on a placeholder? If you were indeed getting it for such a thing? Both these boards are mediocre, but adequate for waiting. I'll swing with the cheaper of the two.
Thats $25 towards a new cooler or somthing u actually plan on keeping.
