I'm running an E6600 on an eVGA 680i board with a Zalman 9700. Temp under load with Orthos is 54C and idle temp is 40C. Is that normal? I want to OC but am not sure about the temps.
With your same setup, excluding the Zalman 9700, I had 25C idle and approx 40C full load.
I'm currently overclocked to 3.2GHz from 2.4GHz, and idle temp is 40C right now. Full load is 55C.
e6600, oc'd to 3.2, Tuniq Tower 120 in an Antec nine hundred. Coretemp shows idle at 19-21C, and after playing a game for a little over an hour the temp log never went over 37C.
